I don't know if this is possible, but I'll ask anyway. Is there a way to setup a Multicast router so that it doesn't act as a DR to itself without setting RSVP points?
I'm trying to do a Multicast on a 2800 router for a MoH stream, and it appears to only be working one way. I think this is the problem:
#sh ip pim int
Address Interface Ver/ Nbr Query DR DR
Mode Count Intvl Prior
10.2.2.3 GigabitEthernet0/0 v2/SD 2 30 1 10.2.2.3
10.2.3.3 GigabitEthernet0/1 v2/SD 2 30 1 10.2.3.3
I'm assuming the core switch should be seen as the DR, not the router itself. Do I need to set the cores as RPs
Tried this:
ip pim rp-address 10.2.2.1
But no change.
