Translation rule
May 4th, 2007
Hi experts
I have a requirements for a customer which wants to redirect External Calling numbers without CallerID to an specific extension.
Is that possible?
If so which rule can i use?
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sat, 05/05/2007 - 02:29
  • Hall of Fame,
    Founding Member
Are you using callmanager? Which version? Which kind of gateway, which kind of lines, which protocol are you running on the gateway?
paolo bevilacqua Sun, 05/06/2007 - 05:08
  • Hall of Fame,
    Founding Member
that should be possible on the GW using a DP with "answer-address", but there could be an easier way made on CCM itself, perhaps someone else knows.
