The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
My network endpoints use the IP addressed vlans on my core cisco layer three core switch as their gateway addresses. i.e.- vlan 11 endpoint address 192.168.11.3/24 with gateway 192.168.11.1/24 (vlan ip on core) and vlan 12 endpoint address 192.168.12...
Hey y'all!I am trying find which port channel member a 2nd switch interface uses? is there a short cut or command that I use for this?Thank you in advance for your help!Inti
I have an EVE-NG lab that consists of a Panorama, 1 FW, and 4 ISE nodes (see lab.jpg attached). The Lab ISE nodes are running 3.2 patch 5 and panorama and Firewall is running 10.2.7-h3. In reading the 3.2 and 3.1 admin guides they both state in the...
Where does one set the FROM e mail address used by CUIC report scheduler to e mail reports? I thought I knew....but it isn't where I thought it was. And I cannot find it in any documentation....
Anyone know if it is possible for a flex AP to cach wired mDNS that has been centrally learned on the WLC? Or does this only work when the AP is in local mode?
Hello,I work on GE in Brazil and we have a MX800 on a room. I was able to share the screen on it, to see myself on cameras, but I couldn't share the video recorded on camera on a Teams Meeting. Can someone support me on how to do this?
CUCM 12.5, I have a Line Group with 3 users, top down then hunt pilot to VM. The RNA Reversion Timeout is set to 15 (per Cisco). One of my users (the first in the line group) sent me a message saying that incoming calls ring to her phone about 10 t...
a. I initiate a WebEx call on my phone (through WebEx App). Audio is working fine. I then plug in the USBc cable into my phone, CarPlay comes up on the car display. I see the call UI on the car display, but no audiob. I initiate a WebEx call from ...
On my Cisco 2960CG running 15.2(2)E10 when I run command show ip igmp snooping detail, among other things I see that IGMPv3 snooping (minimal) is enabled. Why is this feature called minimal? What is missing from normal v3? Is there any official Cisco...
Hello All,I have a 9500 that does not allow EIGRP. How do I enable it on the 9500 series switch?C9500(config-if)#ip router ?isis IS-IS Routing for IPVersion: Version 17.8.1rThank you for your insight.J
After searching through other posts, my config seems OK but still strange behaviourasa 9.20 running on FPWR chasisI cannot get in enabled mode when connecting to ASA via console.It used to work but stopped after I played (disable and restore) with aa...
Hello,I'm reaching out regarding a configuration issue we're experiencing with our 2921 router and the 4 port Gigabit EtherSwitch EHWIC card installed. Despite our efforts, we haven't been able to successfully configure the card to allow connections ...
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
Hello,could you tell me if there is any way to access Meraki sandbox? When trying to use Always On lab i am unable to access it, i am hitting MFA requirement: "Enter verification code Please open the authenticator app on your mobile device and enter ...
I have a question that I am not understanding about docker networks, Macvlan and ipvlan. In the first example, I want to show you the macvlan bridge mode network. This works correctly for me, I show you what I have done to make it work correctly. 1. ...
