Vlan trunking
Answered Question
May 4th, 2007
Does a 2900XL switch support both ISL & 802.1q trunking or like the 2950 just 802.1q????
Correct Answer by ankbhasi about 9 years 11 months ago
Hi Andy,
Yes it does support both ISL as well as dot1q.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/c2900sa4/sa4sc/masctrnk.htm
Ankur
Correct Answer by mohammedmahmoud about 9 years 11 months ago
According to this document, Inter-Switch Link (ISL) trunking is supported on the 2900XL since Cisco IOS Release 11.2(8)SA4 (Enterprise Edition Software):
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_tech_note09186a008017f86a.shtml#subtopic2h
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/2935wc16/ol256212.htm
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_configuration_example09186a00800a875b.shtml
NOTE: The Catalyst 2940 and 2950/2955 series switches do not support ISL encapsulation.
HTH, please rate if it does help,
Mohammed Mahmoud.
Correct Answer by mahmoodmkl about 9 years 11 months ago
it only supports dot1q
Mahmood
Overall Rating: 5 (4 ratings)
Correct Answer
mahmoodmkl Fri, 05/04/2007 - 23:15
  • Gold, 750 points or more
Mahmood
Correct Answer
mohammedmahmoud Fri, 05/04/2007 - 23:29
  • Green, 3000 points or more
Mohammed Mahmoud.
mahmoodmkl Sat, 05/05/2007 - 11:14
Sorry guy's i thought he is asking about 2950.
Mahmood
