question about QoS and 'police' command
May 5th, 2007
hi folks,
in a policy map, when I use the 'police' command without transmit/exceed/violate action specifications, there's an implicit exceed-action drop?
Example:
policy-map Test
class X-Traffic
police 64000
exit
In this case, I've a policer always-on for the X-Traffic, and traffic exceeded 64k will be dropped?
Thanks for your support
Andrea
Overall Rating: 5 (1 ratings)
royalblues Sat, 05/05/2007 - 05:11
Yes the traffic will be dropped if it exceeds the rate you have configured.
If you do not want the traffic to be dropped, you can instead shape the traffic (provided the traffic is not delay sensitive)
Policing discards excess packets, so that overall policed rate is not exceeded whereas shaping enqueues the excess packets which are removed from the queue at the shaped rate
HTH, rate if it does
Narayan
