Finding an IP Address
Answered Question
May 5th, 2007
Here's the setup:
One 6509 with FWSM and its 5 security contexts. Hosts are directly connected to the 6509, but are routed through security contexts.
I have an IP address of one of the hosts off the router. The IP obviously wouldn't show up on the ARP table. I get the security context's outside IP when I do a sh ip route x.x.x.x.
So, how do I find out which port contains the host with this IP? Am I out of luck without having a MAC?
Thank you.
Correct Answer by Jon Marshall about 9 years 10 months ago
Hi Greg
Could you not just look at the arp table within the right FWSM context which would give you the mac-address which you could then track down on the 6500 chassis.
Have i misunderstood the issue ?
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 05/07/2007 - 07:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Greg
Jon
