call fallback active problem
May 5th, 2007
PBXA-PRI-2851---IP-----2851-PRI--PBXB.
Calls between two PBX are fine with this setup. Then I tested the busyout monitor probe IP, which requires call fallback command, so taht when IP down PBX will re-route call to PSTN automatically. However as soon as I added call fallback active, call not working anymore. Debug voip ccapi inout shows H323call setup just does not receive on the other router at all. Has anybody seen this before?
paolo bevilacqua Sun, 05/06/2007 - 05:01
  • Hall of Fame,
    Founding Member
have you configured the parameters ?
call fallback threshold delay loss
call fallback threshold icpif
These have no default values so I guess unless configured properly the effect would be to block all calls.
