orange light on the C-100 front panel
May 5th, 2007
Guys today during customer visit on C-100 mention amber light ,
did check all error logs and system logs nothing , did check disk nothing ,
did clear all messages , did clear all qurant. space , upgrade to 5.1 , rebooted two times still orange light , any idea what might be wrong ?
contacted support , but waiting for an answer maybe you had seen it ...
si_ironport Tue, 05/08/2007 - 22:01
What is the message scrolling across the front panel? The knowledge base has a description of all these error messages.
ogomes_ironport Fri, 05/18/2007 - 20:59
I have the same problem and everything works well. I have my hardware blinking for 8 months and still yet.
I checked in knowlodge Base and tells about problem with hardware or temperature, like you said... there is no frontal screen.
