Transcoding Conferencing
Answered Question
May 5th, 2007
i have a scenario with a WAN and of course a need for G.729 codec. This is Ok, the things gets complicated when we have Auto Attendant or CUE where they need G.711. I have enabled Transcoding for each location (using the WAN Router, which is as well the VG)
I have CCM centralized cluster, the problem shows when the customer needs conferencing over the wan, i haven't tried it yet, but i can feel the problem is coming: in fact i have two MRGL for each location containing its own transcoder and have a software conference (means restricted to G.711) if i tried to add a hardware conference i cannot do it as it needs to use the same name or IP as i already use in the transcoding. Also the same goes for the router SCCP configuration.
In summary can i use the same router to do the conferencing and transcoding if yes please send me the config example.
sorry for this long explenation :-)
Good day
Correct Answer by rchilcote about 10 years 2 weeks ago
Here's an example config with transcoding, conferencing, and a router software MTP on the same ISR router. This config will not work on older non-ISR routers, but you can still use transcoding and conferencing at the same time with those routers with a different config.
sccp local GigabitEthernet0/0.80
sccp ccm 10.120.173.240 identifier 2 version 4.1
sccp ccm 10.120.173.241 identifier 1 version 4.1
sccp
sccp ccm group 10
bind interface GigabitEthernet0/0.80
associate ccm 2 priority 2
associate ccm 1 priority 1
associate profile 20 register 3825-CNF
associate profile 21 register 3825-XCD
associate profile 22 register 3825-MTP
dspfarm profile 21 transcode
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 12
associate application SCCP
dspfarm profile 20 conference
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 4
dspfarm profile 22 mtp
codec g711ulaw
maximum sessions software 10
Hope this helps.
Overall Rating: 4 (2 ratings)
Correct Answer
rchilcote Sun, 05/06/2007 - 09:03
  • Bronze, 100 points or more
sccp
sccp ccm group 10
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 12
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 4
codec g711ulaw
Hope this helps.
DANIEL COHEN-LAROQUE Mon, 05/07/2007 - 05:57
In addition to previous answer, I found effective to reduce range of supported codec for conference (i.e. G711), and support also G729 (as in the example) for only the transcoder.
This allows more sessions to be supported by a single DSP for conferences (max 8). Transcoders will be used automatically (running on other DSP chips) if a conference participant is calling w/ G729.
