SSL VPN Licence
May 6th, 2007
I have an ASA5520, software 7.2(1) with VPN Plus licence.
What licence do I need to use SSL VPN connectivity? Can I use CSD for 100 remote users with the licence I have.
ggilbert Mon, 05/07/2007 - 08:29
  • Cisco Employee,
If you do sh version, you should be able to see the number of webvpn peers that are allowed to connect to your ASA.
CSD will be counted against the webvpn peer license.
Rate this post, if it helps.
Gilbert
