05-06-2007 01:38 AM - edited 03-11-2019 03:09 AM
Hi all,
In my organization we have a pix515e. We want to buy a failover pix, but now they recommend us to put away our pix and buy an ASA.
Can you tell me what are the differences between ASA and PIX.
Is the configuration a bit the same on both platforms? With my knowledge of pix, can I configure an ASA too?
Stella
Solved! Go to Solution.
05-07-2007 06:20 AM
There are several changes in the ASA CLI that you should be aware (but not afraid) of. The interface configuration is more IOS like now. Also, vpn's are configured a little differently using the concept of groups. I know PIX 7.x will accept old style vpn commands and automagically convert them, but I don't know if the ASA has this logic. Also, the 7.x no longer supports conduits in either PIX or ASA.
The fixup commands have been deprecated in the 7.x OS, in favor of inspection maps (again, more IOS like syntax).
These examples scratch the surface of the differences, but are most likely the ones you will first encounter.
In short though, if you know PIX 6.x (or 7.x), the ASA should be easy to pickup.
05-06-2007 05:05 AM
Stella, with your knowledge of PIX 515e you should be able to quickly learn the new ASA plaform, personaly I have not used the ASA but rather PIX515e and 501s, I bought a ASA book with the intend to learn what I currently support in which shows command syntax for both the PIX500s and ASA, the CLI is same, but It is obious as in any new platform that we are face with new CLI and features to learn, the ASA is the next generation for cisco's security applience ASA's functionality is far more widen that that of PIX500s in addition to new functions that you have to learn, since you know the PIX500's here are couple of links to compare to with ASAs.
Here are couple of links to refer to:
ASA models comparison
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Migrating from PIX 500 to ASA
http://www.cisco.com/en/US/products/ps6120/prod_brochure_list.html
Hope this helps
Jorge
05-07-2007 03:22 AM
Jorge,
Thanks for your reply. The links you send me are very helpfull.
Stella
05-07-2007 06:20 AM
05-07-2007 10:46 PM
Thanks Steven!
Stella
