Cant forward ports (1750 router)
May 6th, 2007
I am trying to configure port 80 and port 5060 to forward to an internal (192.168.0.52) address. So far, I have been unsuccessful. I copied the command off another topic in this forum, but it isnt working. I tried doing a 'debug ip nat' while I try to access the external IP address in my browser, but I get no activity.
Config is below.
Any help would be greatly appreciated.
Current configuration : 1772 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname cygnus_bastion
enable secret *PASSWORD*
memory-size iomem 15
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip domain-name internode.on.net
ip name-server 192.231.203.3
ip audit notify log
ip audit po max-events 100
vpdn enable
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
no fair-queue
hold-queue 224 in
interface ATM0.1 point-to-point
no ip mroute-cache
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
ip address 192.168.0.1 255.255.255.0
ip nat inside
speed auto
full-duplex
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname *USERNAME*
ppp chap password *PASSWORD*
interface Dialer1
no ip address
priority-group 1
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.0.52 5060 interface Dialer0 5060
ip nat inside source static udp 192.168.0.52 5060 interface Dialer0 5060
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip pim bidir-enable
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 10 permit 192.168.0.101
access-list 10 permit 192.168.0.52
priority-list 1 protocol ip high list 10
priority-list 1 default low
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
password *PASSWORD*
login
no scheduler allocate
end
mohammedmahmoud Sun, 05/06/2007 - 09:53
  • Green, 3000 points or more
Can you please paste the "show ip nat translations" output.
BR,
Mohammed Mahmoud.
jordan.ross@dem... Sun, 05/06/2007 - 18:37
cygnus_bastion#show ip nat translations
Pro Inside global Inside local Outside local Outside global
udp 121.44.59.38:5060 192.168.0.52:5060 --- ---
tcp 121.44.59.38:5060 192.168.0.52:5060 --- ---
tcp 121.44.59.38:4865 192.168.0.151:4865 203.16.214.182:110 203.16.214.182:110
tcp 121.44.59.38:4862 192.168.0.151:4862 121.44.19.38:80 121.44.19.38:80
udp 121.44.59.38:80 192.168.0.52:80 --- ---
tcp 121.44.59.38:80 192.168.0.52:80 --- ---
udp 121.44.59.38:5060 192.168.0.52:5060 203.2.134.1:5060 203.2.134.1:5060
tcp 121.44.59.38:4849 192.168.0.151:4849 72.14.253.99:80 72.14.253.99:80
tcp 121.44.59.38:4850 192.168.0.151:4850 72.14.253.99:80 72.14.253.99:80
udp 121.44.59.38:1301 192.168.0.52:1301 192.231.203.132:123 192.231.203.132:12
icmp 121.44.59.38:768 192.168.0.151:768 121.44.19.32:768 121.44.19.32:768
cygnus_bastion#
mohammedmahmoud Mon, 05/07/2007 - 22:11
According to you configuration and output, there is no networking side problem, can you please check the systems side.
HTH, please rate all helpful posts,
Mohammed Mahmoud.
