PIX Error msg
May 6th, 2007
hi guys,
i have a pix 515 which is running 7.22 . till few weeks back it was working fine. but today suddenly it stoped responding . when i try to go to the monitor mode and upgrade or downgrade. this MSG comes on the screen
isco Secure PIX Firewall admin loader (3.0) #0: Thu Aug 4 21:23:30 PDT 2005
Flash=i28F640J5 @ 0x300
BIOS Flash=AT29C257 @ 0xd8000
An internal assertion check has failed.
Copy the following message exactly as it appears,
along with any visible version strings, and
then call your support representative.
assertion "addr < STRATA_CHIPSIZE" failed: file "../flash/strata.c", line 257
can anyone tell me whats this or whats the problem with the device .
regards
amit
Overall Rating: 5 (1 ratings)
zulqurnain Sun, 05/06/2007 - 13:14
hello,
What you need is a file "erasedisk622.bin" from Cisco
Power system off, wait a few seconds, power up and hit Esc to get to
monitor>
TFTP this file and it will ask you if you want to erase the disk. Say yes.
After it's done, you can then tftp the 6.3 image over, pull in the config, then upgrade to 7.0x.
That upgrade will convert the file structure and the config file. Save this new config off somewhere
Now you can upgrade to 7.22 and have 2 "flavors" of your config - old 6.3 and new 7.x
HTH, please rate it.
amitbatra Sun, 05/06/2007 - 17:47
hi my friend,
thanks for ur reply. well i tried to download erasedisk622.bin from cisco. but i couldnt find that file on the website. i have erasedisk611.bin will that help me ?
regards
zulqurnain Sun, 05/06/2007 - 20:41
hello,
i am really not sure if erasedisk611.bin will work for you or not! so no suggestions.
amitbatra Sun, 05/06/2007 - 20:57
hi,
i have erasedisk611.bin.. but i was unable to loacte 622.bin. can u please put me in right direction from where i can get this file.
regards
amit
