reload a virtual context in ACE
ROMAN TOMASEK
is possible to reload one or more virtual contexts in ACE module? Is possible to download checkpoints from ACE to remote server and vice versa?
Thank you
Roble Mumin
Level 3
Level 3
You can't reload a single context, maybe they will change this with a next major. Copying a checkpoint is also not possible imho. So if you delete a context the whole checkpoints are gone.
If you want to do a write erase and reload for a fresh start you have to create an initial "empty" checkpoint and roll back.
Easiest way to create a fresh context and make sure it has the same configuration is copy and paste from a config file but you have to be careful in which order. If you e.g. reference a cert which is not in the store or paste an ssl-proxy into a service policy without the ssl-proxy part configured etc.
But as always maybe someone has even better advice.
Roble
Roble Mumin
Level 3
Level 3
Roble
