2821 as Firewall/MLPPPx4xT1/VPN(ipsec) and nat for some hosts
May 6th, 2007
Internet Router/Firewall/VPN with 4xT1--------Internal LAN
Will this work?
the MLPPP will be the outside but what will the Firewall use as it's outside address.
We also have a class C network. How can I use the class C network on the outside firewall and VPN portion?
bjornarsb Mon, 05/07/2007 - 06:04
If Router/Firewall/VPN is the same box,
the outside ip would be the one assigned to your dialer interface. You can have the class C nettwork assigned on the LAN int of the 2821.
If you want a portion of the class C nettwork on the outside, and your provider agree you can use ip unnumbered fa0/0 on your dialer interface.
