mohammedmahmoud Sun, 05/06/2007 - 09:40
  • Green, 3000 points or more
To connect a PC to a router via Ethernet, there are 2 options, either use a crossover cable to connected them directly via the Ethernet ports, or use a switch between them and use straight cables.
As for connecting a PC to a router via the com (serial) port, you'll have to connect the serial com port of the PC to the router console port via the RJ-45-to-DB-9 cable, and then use a terminal program such as Windows Hyper Terminal, or the famous SecureCRT to do terminal access to the router.
Configure your terminal program like this;
* Speed - 9600
* Data Bits - 8
* Parity - none
* Stop bits - 1
* Flow Control - none
HTH, please do rate if it does help,
Mohammed Mahmoud.
networking11 Sun, 05/06/2007 - 09:51
Ya, what is this secure CRT , and can i know wheter there is any document provided for this basic elements
mohammedmahmoud Sun, 05/06/2007 - 09:59
SecureCRT is the famous and most commonly used terminal emulation software (it is more advanced than the Windows built in Hyper Terminal), it supports SSH1, SSH2, Telnet, Telnet/SSL, RLogin, Serial, and TAPI protocols, you'll need it to console access your router.
http://www.vandyke.com/products/securecrt/
HTH, please do rate all the helpful replies,
Mohammed Mahmoud.
