Display Number of Missed Calls
May 6th, 2007
Just wondering if anyone knows if you are able to alter the "11 Missed Calls" display on IP Phones? Is it able to be modified such as Init:CallHistory wipes all call history?
It must be stored in the phne somehow...
stephan.steiner Mon, 05/07/2007 - 00:05
It's not possible. You can override the status line via CTI (TAPI only), but if you want something visible all the time (as an example) the only choice you have is write a CTI app that keeps your own call lists.
