PEAP configuration in AP 1100
May 6th, 2007
How to configure for peap in AP 1100 through CLI
micdenne Wed, 05/09/2007 - 09:45
Hi Sanjoy2006.
This may depend on which IOS version you are running on your 1100 series access points. Here is a link to the configuration guides for the 1100. You can select the applicable software version and the section you would look for would be "configuring authentication types". Here is the link to the wireless configuration guide page:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_installation_and_configuration_guides_list.html
Another resource which might be helpful includes the AAA - Access Control Server - Configuration guidelines as well as some info about CLI configuration of the access points. This can be found here:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a0080545a29.shtml
Hope this helps
rochopra Fri, 08/03/2007 - 02:34
Following link can give you information on configuration of EAP through GUI and CLI:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801bd035.shtml
Remember PEAP is not something which you setup on AP, AP has a default configuration to allow EAP protocol.
The settings related to protocol selection like PEAP, EAP-TLS etc needs to be done on Radius Server and Client machines.
Following link can give information on configuration of Radius server and client machines:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00801df0e4.shtml
Hope this helps.
~Rohit
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
