aaa authorization is confusing
May 6th, 2007
hi...this command make me mess for many times :(. is it true aaa authorization can return acl and time for user? how aaa authorization know what user will be associated in case aaa authentication is aaa authentication login default local? for make it more aaa authorization only work with tacacs? tx a lot ;)
bjornarsb Tue, 05/08/2007 - 03:54
If the tacacs server fails to respond, then local network authorization will be performed.
Assuming this command: aaa authorization network test tacacs local.
Keep in mind that only a limited set of functions can be controlled via the local database.
