vpn thru wireless
Answered Question
May 7th, 2007
is it possible to do an ipsec site to site vpn on routers tha is linked thru wireless?
thanks
Correct Answer by ggilbert about 9 years 9 months ago
Celso,
If both the routers are
a. able to communicate between each other
b. there isn't much lag,
c. and there isn't anything on the wireless devices that would block UDP 500 and ESP packets,
then you should not have a problem with the Site to Site tunnel establishment.
Hope this answers your query.
Rate this post, if it helps.
Cheers
Gilbert
Overall Rating: 3 (1 ratings)
Correct Answer
ggilbert Mon, 05/07/2007 - 08:34
Celso,
Cheers
Gilbert
