PAT ISSUE
Answered Question
May 7th, 2007
I have two routers connected through Public carrier provided MPLS netwro.
Both can ping on thier serial interfaces alongwith service provider end IPS. but failed to ping on each other local fast ethernet.
The configuration of Router 'A' is here:
interface FastEthernet0/1
description ## KHI Gateway to MPLS ###
ip address 192.168.15.250 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/1
description #link to MPLS#$FW_INSIDE$
ip address 221.x.x.34 255.255.255.252
ip nat outside
router eigrp 1
network 192.168.0.0
network 192.168.2.0
network 192.168.9.0
network 192.168.10.0
network 192.168.13.0
network 192.168.14.0
network 192.168.15.0
network 192.168.16.0
ip route 0.0.0.0 255.255.255.252 221.120.192.33
ip route 202.x.x.96 255.255.255.252 221.120.192.33
ip http server
ip http access-class 71
ip http authentication local
ip nat pool outer 192.168.16.0 192.168.16.254 netmask 255.255.255.0
ip nat inside source list 7 interface Serial0/0/1 overload
ip nat outside source list 8 pool outer add-route
access-list 7 permit 192.168.15.0 0.0.0.255
access-list 8 permit 192.168.16.0 0.0.0.255
Router 'B'
interface Serial0/1/0
description ITI SERIAL
ip address 202.x.x.98 255.255.255.252
ip nat outside
interface FastEthernet0/0
description CONNECTION TO MY NETWORK
ip address 192.168.16.250 255.255.255.0
ip nat inside
speed auto
full-duplex
no mop enabled
router eigrp 1
network 192.168.0.0
network 192.168.2.0
network 202.x.x.0 0.0.0.7
network 221.x.x.0 0.0.0.3
ip classless
ip route 0.0.0.0 0.0.x.x.125.147.97
ip route 0.0.0.0 255.x.x.252 202.125.147.97
ip http server
ip nat inside source list 8 interface Serial0/1/0 overload
access-list 8 permit 192.168.15.0 0.0.0.255
Any help highly apperciated
Correct Answer by vijayasankar about 10 years 1 month ago
You should inform your service provider that you are having 192.168.15.0/24 network at Location A and 192.168.16.0/24 network at location B. So that the service provider will add necessary routes on his MPLS PE router.
If you service provider adds the neccesary routes in his end devices, you will be able to access LAN communication between both sites.
Only If your service provider also configure EIGRP at the PE Router and supports it for you, you will be able to advertise your networks dynamically through EIGRP.
Please discuss with your service provider to proceed further.
-VJ
Overall Rating: 3 (1 ratings)
mrmozaffari Mon, 05/07/2007 - 02:11
Let to forget about Dynamic routing now i mean eigrp ,use static routing to test the connectivity ,now take a look to this line in your configuration :
What it means ?
it should be like this :
ip route 0.0.0.0 0.0.0.0 221.120.192.33
I hope this will solve your problem.
Please rate helpful posts.
Best Regards B.Mozaffari
vijayasankar Mon, 05/07/2007 - 02:19
  • Silver, 250 points or more
At Router A, you don't need the ip nat outside.
Remove that "ip nat outside and corresponding statements on Router A.
At Router B, i dont see that the local network 192.168.16.0 is included in Eigrp.
Also the ACL 8 on Router B,should not include the network 192.168.15.0. Remove that.
To summarise,
On Router A, perform the following.
no ip nat outside source list 8 pool outer add-route
no access-list 8
On Router B, perform the following
router eigrp 1
network 192.168.16.0 0.0.0.255
no access-list 8
Also i could see some strage static routes on both the routers.
Router A:
Router B:
ip route 0.0.0.0 0.0.0.0 202.125.147.97
ip route 0.0.0.0 255.255.255.252 202.125.147.97
Please correct the same.
-VJ
shahzadrana Mon, 05/07/2007 - 02:43
Hi VJ
I am sending again the updateted output of Sh run command:
Router 'A'
version 12.3
service password-encryption
hostname OLPHO3
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
description # Fast Ethernet Connection 1 #
ip address 192.168.0.248 255.255.255.0
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
ip address 221.120.192.34 255.255.255.252
ip nat outside
router eigrp 1
network 192.168.0.0
network 192.168.2.0
network 192.168.9.0
network 192.168.19.0
network 192.168.100.0
network 202.125.147.0 0.0.0.7
network 221.120.192.0 0.0.0.3
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 255.255.255.252 221.120.192.33 (this is the ISP end edge router IP)
ip route 192.168.16.0 255.255.255.0 221.120.192.33
ip route 192.168.16.0 255.255.255.0 202.125.147.97
ip route 202.125.147.96 255.255.255.252 221.120.192.33
ip http server
access-list 71 permit 192.168.0.5
access-list 99 permit 192.168.0.62
access-list 99 permit 192.168.0.5
access-list 99 deny any
access-list 101 permit ip any any
access-list 108 remark 8
access-list 108 remark SDM_ACL Category=2
access-list 108 permit ip 192.168.15.0 0.0.0.255 192.168.16.0 0.0.0.255
access-list 169 permit icmp any any echo
access-list 169 permit icmp any any echo-reply
access-list 169 permit udp any any eq echo
access-list 169 permit udp any eq echo any
access-list 169 permit tcp any any established
access-list 169 permit ip any any
dialer-list 1 protocol ip list 101
control-plane
banner login ^C ^C
banner motd ^C Welcome To OLPHO ISDN Router ^C
line con 0
login local
transport output telnet
line aux 0
login local
Router 'B'
Current configuration : 1713 bytes
version 12.4
hostname ORIX-MPLS
boot-start-marker
boot-end-marker
enable secret 5 $1$D54Q$j6R5yWaLSGH7XzPcsA5iW.
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip name-server 202.125.148.204
isdn switch-type basic-net3
ip nat inside
speed auto
full-duplex
no mop enabled
ip address 202.125.147.98 255.255.255.252
ip nat outside
interface Serial0/1/1
no ip address
shutdown
clockrate 2000000
router eigrp 1
auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 202.125.147.97 (the 202.125.147.97 is the ISP edge router address)
ip http server
end
vijayasankar Mon, 05/07/2007 - 02:46
ACL 8 is missing in Router B.
Include these lines on Router B.
-VJ
mrmozaffari Mon, 05/07/2007 - 02:47
Hi again
Please change this line
to this and examine what will happen.
Thanks.
shahzadrana Mon, 05/07/2007 - 03:02
mr. mozaffari
Sorry i dont understand ur statement
Shahzad
vijayasankar Mon, 05/07/2007 - 02:49
As pointed out by the fellow Netpro, please remove the incorrect static route on Router B.
no ip route 0.0.0.0 255.255.255.252 202.125.147.97
It should have only one default route.
-VJ
shahzadrana Mon, 05/07/2007 - 02:56
hi VJ
remove the incorrect address. but still failed to ping remote LAN
Thank u
vijayasankar Mon, 05/07/2007 - 03:07
As you are having the MPLS links connecting to both the sites, do you really need NAT to access the remote lan segments.
I just had a look at the configuration and your initial requirement.
You want lan to lan access, in this case PAT is not going to help.
If you receive the lan routes via EIGRP properly, then you dont need to do NAT at all.
Does your service provider instructed you to turn on EIGRP to advertise your subnets.
If this is the case which is usually, you dont need to do NAT / PAT at both ends, you should be able to access the lan segments mutually at both locations.
Kindly clarify me on your setup to help you better.
-Vj
shahzadrana Mon, 05/07/2007 - 03:15
Yes, you are right. This is a MPLS link connecting both sites, usualy NAT and PAT not required to access remote lan segments.
I am using leased line on other router and eigrp protocol and it works fine with lan routes. My service providor not asked me to turn on the eigrp. but what else we should use instead of eigrp.
Thanks again
Correct Answer
vijayasankar Mon, 05/07/2007 - 03:21
-VJ
shahzadrana Mon, 05/07/2007 - 03:42
Thank you VJ.
I forwarded your suggested guidelines to our service provider.
Best Regards
Shahzad
