05-07-2007 01:26 AM - edited 03-09-2019 05:56 PM
I have to identisk 3020 Concentrators with same softtware vers. vpn3005-4.7.2.J-k9.bin. But I have just SSL VPN client option in one af them. What is problem. Thanks a lot in advance.
Sfanayei
05-07-2007 07:57 AM
SSL Client can be downloaded from CCO and installed on the concentrator.
Note: The concentrator software DOES NOT come with the SSL VPN client.
Here is the link to get the SSL client.
http://www.cisco.com/cgi-bin/tablebuild.pl/sslvpnclient
Rate this post, if it helps.
Cheers
Gilbert
05-08-2007 01:08 AM
But I think. SSL Client coms with Software vers. 4.7.x above. Any way I have tryied to install ssl client, but uploading the sslclient.pkg reach only 74% than I lose ip conectivity to Concentrator.
Thanks in advance
Sfanayei
05-08-2007 05:36 AM
The software version of the concentrator 4.7.x does not come with the SSL VPN client already installed on it.
You have to load the SSL Client separately on the concentrator.
Hope this helps.
Gilbert
05-08-2007 11:24 AM
But Can you tell me why do I have the SSL option in one them even dow they have same software. And do you know that which software vers. can i use?
Thanks again
Sfanayei
