Warning message
From IOS to CSM Module Configuration
May 7th, 2007
Hi All,
I have a very simple SLB configuration on my 6509 switch running IOS. I tried moving the configuration from IOS to the CSM Module. I did this by simply removing the ip slb commands and writing the same configuration under module CSM #. Once the config was done I saved it, but it did not work. I have only this one CSM in the switch; is there something else I need to do? Do I have to change from RP mode to CSM mode?
Thank you,
Scott
network_dude Wed, 05/09/2007 - 06:35
Does anyone have any ideas on this? I have to be missing some simple command or something...
Thanks in advance,
Scott
