Primary and Secondary ACS replication issues in ACS 4.0 for Windows
May 7th, 2007
What is the procedure of replication between primary acs and secondary acs while primary acs is installed with self generated certificate for EAP-FAST and for SSL enabled interface to Primary ACS
is it mandatory to generate certificate on secondary ACS for successful replication between primary and secondar ACS.Any suggestions will be of great help
Thanks in advance
Ahmed
jhillend Mon, 05/07/2007 - 12:14
  • Bronze, 100 points or more
First, all details for ACS replication can be found here:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs41/user/scadv.htm#wp755988
Next, certificates are not required or used for for database replication.
If you are going to replicate EAP-FAST and interface settings, then you will need to configure a separate self-signed cert on the secondary ACS.
