help with hairpinning
May 7th, 2007
I'm using ASA5520 with 7.2
Inside Interface 192.168.0.0/19
Outside Interface 111.111.111.128/27
With hairpinning enabled, I can access webservers from the inside of the network using their public IPs that are natted back to the inside. This works great right now.
My ISP gave me a second Public IP block to add to my existing Public network, call it 222.222.222.128/27
How do I allow the new 222.222.222.128/27 network to be also hairpinned?
acomiskey Tue, 05/08/2007 - 07:55
  • Green, 3000 points or more
You should only have to add an additional static statements for the new servers addresses. Your existing hairpin probably looks like this...
static (inside,outside) 111.111.111.x 192.168.0.x netmask 255.255.255.255
static (inside,inside) 111.111.111.x 192.168.0.x netmask 255.255.255.255
New network hairpin...
static (inside,outside) 222.222.222.y 192.168.0.y netmask 255.255.255.255
static (inside,inside) 222.222.222.y 192.168.0.y netmask 255.255.255.255
