Voice Port stay Up when transfer to PSTN
May 7th, 2007
Hello guys, i have a problem,
When i try to forward my Phone to PSTN my voice port stay UP and never hang up.
0/0 -- fxo-ls up up idle off-hook y
0/1 -- fxo-ls up up idle off-hook y
What can i do to resolve this issue.
Regards.
Brandon Buffin Mon, 05/07/2007 - 07:25
  • Purple, 4500 points or more
If you receive a call from the PSTN to your phone and have your phone forwarded to a PSTN number, it is normal behavior for these 2 ports to stay active for the duration of the call. If the ports are not disconnecting after the call is terminated, take a look at the following link for cause of this problem and possible solutions.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Hope this helps. If so, please rate the post.
Brandon
robert.bernal Mon, 05/07/2007 - 07:50
Thanks bbuffin, Its done I use commands
battery-reversal
no supervisory disconnect signal
Now, when tha call is over, it self dissconect and comes down.
Thanks for your help.
