?Fiber polish for 1000baseZx GBIC
May 7th, 2007
Do the fiber ends mating with a 1000baseZx GBIC require ultra polish (UPC) or angle polish (APC) termination?
Can you send me a url to a specification for this?
vmiller Mon, 05/07/2007 - 07:46
I would strongly suggest purchasing fiber jumpers instead. Have a qualified tecnician build out the fiber backbone plant to patch panels and then just use jumpers with the correct ends to connect to the gbics.
steve.dutky Mon, 05/07/2007 - 08:06
Thank you.
I inherited an extended demarc patch panel with single mode SC/APC terminations.
I can order patch cords with SC/APC at one end and either SC/UPC or SC/APC on the other.
Which one (if any) best mates with the 1000baseZX gbic?
scottmac Mon, 05/07/2007 - 08:09
I believe the angle polish is used for WDM connection.
I'm pretty sure you'd want the UPC.
Good Luck
