PIX newbie, IP settings
Answered Question
May 7th, 2007
I'm setting up a 506e for the first time. I want to change the inside IP address to 192.168.0.1 (DHCP server disabled), but PIX complains that address is not in DHCP pool. I can't change pool without conflict with network address.
Why won't PIX allow a networy address change if DHCP server is disabled?
Help, please!
dpm
pixfirewall# config t
pixfirewall(config)# no ip address inside dhcp
pixfirewall(config)# ip address inside 192.168.0.1 255.255.255.0
Interface address is not on same subnet as DHCP pool
pixfirewall(config)# exit
pixfirewall#
The error has something to do with DHCP pool. Honestly it appears to be a bug since DHCP is disabled.
Just remove the references below and hopefully it will work.
Do a the following;
config t
no dhcpd address 192.168.1.2-192.168.1.254 inside
no dhcpd lease 3600
exit
wr me
Let me know if it works.
Overall Rating: 5 (1 ratings)
nagel Mon, 05/07/2007 - 07:42
Please post config and I can help you
ddidpm506 Mon, 05/07/2007 - 08:02
Sorry, I'm *really* a newbie. How do I extract the current config as a text file? I'm using the PDM tool.
dpm
nagel Mon, 05/07/2007 - 08:10
Your gonna need to lose the PDM thingy. I would suggest getting the free terminal program called "putty" and then use it to telnet into the pix. Once you are into the pix using putty you can issue the sh run command. Right click in the putty header bar (at top of screen) and select 'copy all to clipboard'. Open up your wordpad/notepad and then right click and do a 'paste'. From here you can print, copy whatever the configuration text.
Really need to see the config in order to be helpful.
putty client can be found at
http://www.chiark.greenend.org.uk/~sgtatham/putty/
ddidpm506 Mon, 05/07/2007 - 08:46
I got putty. If I choose "SSH" it replies "connection refused"; if I select "telnet" putty just exits.
I'm really sorry to be a pain, but I don't understand why this is so difficult.
dpm
nagel Mon, 05/07/2007 - 09:39
I am assuming that you are entering the correct IP for the telnet session. Sounds like you do not have telnet enabled on the PIX. Can you check that with PDM. Not really so difficult but virtually no one that is responsible for a PIX uses the PDM. So I guess I am at a disadvantage in that I have just barely seen what the PDM interface looks like.
jamesrose Mon, 05/07/2007 - 10:43
While in the PDM, go to File, Show Running config in New Window, login and then do a file, save as, change the file type to text and save it where you want it.
nagel Mon, 05/07/2007 - 14:07
you have the following dhcp entries in your config
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
I think you can remove these by issuing a 'no dhcpd' command while in the pix. Note the d at the end of dhcpd
Additionally you have no telnet or ssh set up your pix so you will need to console in with the blue cisco cable that came with your pix. Do this using hyperterminal and the com settings are
9600
n
8
Additionally note that in order for the pix to work you must have a different subnet on each side (inside/outside)
ddidpm506 Mon, 05/07/2007 - 10:26
IP address is factory default: 192.168.1.1
The 506e is running 6.3(5).
dpm
ddidpm506 Mon, 05/07/2007 - 11:25
Here's what I got:
pixfirewall#
Odd, huh?
Dean
ddidpm506 Mon, 05/07/2007 - 12:01
Well, PDM shows the DHCP servers disabled on both ports.
dpm
Correct Answer
pixfirewall#
Do a the following;
config t
no dhcpd lease 3600
exit
wr me
ddidpm506 Tue, 05/08/2007 - 05:12
Your procedure seemed to work - I can now ping the inside port at 192.168.0.1. I lost contact with the internal web server, but when I changed it's address to 192.168.0.1 it started working again.
Thanks for your help.
dpm
