05-07-2007 07:40 AM - edited 03-03-2019 04:52 PM
Hi Friends .. Manoj here
I have an interesting issue with one of my access servers for which i need your help.
I am using cisco 2610 as my Access Server. I have about 8 devices connected to it which have TACACS authentication. After logging into the access server, i issue "Menu top" for the list of devices. After selecting a particular device, i am prompted for my TACACS login. But once i enter the user name and my token passcode, it just seems to hang and doesnt seem to be doing anything.
Username: *********
Enter PASSCODE:
But if I enter a wrong user name and password, then i get error
Username: *******
Enter PASSCODE:
% Authentication failed.
Looking forward for your expert advices on resolving the issue. Cheers !!!
- Manoj
05-07-2007 09:21 AM
I think that unless you provide some more information, it's unlikely that you will get an useful reply. Like:
Was it working before?
Is the tacacs server running fine ?
IOS used?
Configuration?
Debugs?
05-07-2007 10:02 AM
Debugs would be good to see from a management session.
debug aaa authen
debug aaa author
Daniel
05-07-2007 10:38 AM
I've been informed that this really never worked since the access server was set up. There is no problem with the TACACS server. The IOS is C2600 Software (C2600-I-M), Version 12.1(27a). Below config might just help
menu top text 1 *****
menu top command 1 resume ***** /connect telnet *****
menu top text 2 *****
menu top command 2 resume *****/connect telnet *****
menu top text 3 *****
menu top command 3 resume *****/connect telnet *****
menu top text 99 Exit Menu to Console
menu top command 99 menu-exit
menu top clear-screen
menu top line-mode
line 33 48
session-timeout 30
no exec-banner
exec-timeout 10 10
password 7 ******888
no flush-at-activation
no exec
transport preferred none
transport input all
transport output none
sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 0 0/0 -
33 TTY 9600/9600 - - - - - 2 0 0/0 -
34 TTY 9600/9600 - - - - - 6 0 0/0 -
35 TTY 9600/9600 - - - - - 1 0 0/0 -
36 TTY 9600/9600 - - - - - 1 0 0/0 -
37 TTY 9600/9600 - - - - - 0 0 0/0 -
38 TTY 9600/9600 - - - - - 3 286899 0/0 -
39 TTY 9600/9600 - - - - - 2 0 0/0 -
40 TTY 9600/9600 - - - - - 10 0 0/0 -
41 TTY 9600/9600 - - - - - 0 0 0/0 -
42 TTY 9600/9600 - - - - - 0 0 0/0 -
43 TTY 9600/9600 - - - - - 0 0 0/0 -
44 TTY 9600/9600 - - - - - 0 0 0/0 -
45 TTY 9600/9600 - - - - - 0 0 0/0 -
46 TTY 9600/9600 - - - - - 0 0 0/0 -
47 TTY 9600/9600 - - - - - 0 0 0/0 -
48 TTY 9600/9600 - - - - - 0 0 0/0 -
65 AUX 9600/9600 - - - - - 0 0 0/0 -
* 66 VTY - - - - 82 88 0 0/0 -
67 VTY - - - - 82 34 0 0/0 -
68 VTY - - - - 82 2 0 0/0 -
69 VTY - - - - 82 1 0 0/0 -
70 VTY - - - - 82 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
1-32, 49-64
05-07-2007 01:01 PM
Enable exec on the lines and see if that resolves this for you.
line 33 48
exec
Daniel
