SSO failed
May 7th, 2007
Error:SSO AS is unreachable. Using non SSO.
The cert on CW was somehow changed to another host and CW was restarted. I changed the host name back to its original name and restarted CW, but the sso error still appears when accessing peers.
Joe Clarke Mon, 05/07/2007 - 08:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Where did you change the hostname? Changing a cert hostname means you had to regenerate the cert. In this case, you must reaccept the cert on your SSO peer server before SSO will work again.
rice.randy Mon, 05/07/2007 - 08:31
I changed it in Server, Security, Certtificate Setup. So I need to re accept the cert on my peer servers?
Joe Clarke Mon, 05/07/2007 - 08:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes. If this was the master, you need to delete the old cert, then reaccept the new one on all slave machines. If this was a slave, you only need to delete and reaccept on the master.
