Calling Name not showing up on H.323 Gateway for Inbound Calls
May 7th, 2007
I have a 2821 gateway I've recently converted from MGCP to H.323. It has 2 PRIs to the PSTN, terminated on a VWIC-2MFT-T1 card.
When I receive an incoming call from the PSTN, the number shows up fine but I no longer see the name. It worked before, and I can verify it is being received from the Telco using "debug isdn q931".
In the Gateway configuration in CCM, I have "Display IE Delivery" checked. Is there something I'm missing?
isdn switch-type primary-ni
controller T1 0/1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
controller T1 0/1/1
framing esf
linecode b8zs
interface Serial0/1/0:23
no ip address
encapsulation hdlc
no logging event link-status
isdn incoming-voice voice
trunk-group PSTN
no cdp enable
interface Serial0/1/1:23
no ip address
encapsulation hdlc
trunk-group PSTN
no cdp enable
voice-port 0/1/0:23
voice-port 0/1/1:23
dial-peer voice 2 pots
description Calls from PSTN
incoming called-number ....
direct-inward-dial
Gateway IOS ver is 12.4(11)T1, CCM ver is 4.1(3)sr4d
Overall Rating: 3 (3 ratings)
gogasca Mon, 05/07/2007 - 08:58
Hi Johny,
If the Gateway is running MGCP and the CCM is running 3.3 or earlier, the Caller ID Name must be in the Display IE.
If the Gateway is running MGCP and the CCM is running 4.0 or higher, the
Caller ID Name can be Display or Facility IE.
If the Gateway is running H323 then CCM is not relevant and the Caller ID Name must be in the Display IE.
thisisshanky Tue, 05/08/2007 - 07:24
Gonz,
Any plans to fix this above issue indicated in the tac case collection ? There are situations where you cant use MGCP all the time, like NFAS trunk groups.
johnnylingo Tue, 05/08/2007 - 14:12
Grrr...my plan was to use H.323 for incoming calls, and MGCP for outbound. Might have to scratch that.
johnnylingo Fri, 11/09/2007 - 00:00
Super, thanks. Hopefully this feature will make its way to the T and mainline trains. I have a customer running an ISR, so convincing them to run the XW train in production is a hard sell. Generally, I prefer H.323 gateways to MGCP for stability and compatibility reasons.
mdeloach Tue, 03/11/2008 - 17:09
Is there an easy/obvious way to determine when this feature might make it into the T series?
I've been in and out of the feature lookup tool and release notes with out finding an answer.
The T series is about as much risk as we are willing to take, and this is a feature that we would really like to impliment.
joshuamarsh Fri, 05/09/2008 - 10:23
Check out CSCsm50874. Looks like Cisco is fixing this on CME. Any word if this will work for CallManager as well? Note the T release below in "fixed in."
CME: calling name in facility IE doesn't display on IP phone
Symptom:
CME 4.2 does not display calling name when sent in an ISDN facility IE message. The facility is received and interpreted correctly however it doesn't show up on the IP phone display.
Workaround:
IOS 12.4(11)XW3 and 12.4(15)XY correct display the calling name.
Fixed-In
12.4(19.3)T1
12.4(15)T5
12.4(15)XZ
12.4(11)XW7
