May 7th, 2007
Does WLSE use the IDS feature on 1242 access point? What are some of the security features on the software? Can it detect rogue access points? What is the difference between WLSE Express or CiscoWorks WLSE software? What is the current full version of the software?
Overall Rating: 5 (1 ratings)
jreekers Mon, 05/07/2007 - 14:34
Your questions are pretty broad (wide-ranging). I think the best place for you to start is here:
There, you'll see data sheets related to each product (WLSE, WLSE Express, WDS, etc.) that should help with many of your questions.
As for some of the more direct questions you ask,
- WLSE detects, locates, and mitigates rogue access points and unauthorized ad-hoc networks.
- v2.9.1a is the latest.
- The Data sheets tell you the difference between WLSE and WLSE Express.
Trending Topics - Security & Network
