Can I enable 802.11b/g on individual radios instead of globally?
May 7th, 2007
  • Bronze, 100 points or more
I am deploying 400 new APs. There is an existing wireless network. I need to turn up some of the radios before I turn up the rest. Right now I have 802.11b/g network turned off globally across all controllers. What I want to know is can I enable 802.11b/g radios selectively on individual APs or does it have to be done globally across the controller?
Thanks.
john.preves Mon, 05/07/2007 - 12:26
  • Silver, 250 points or more
Yes you can...wireless/access points/b/g radios/configure
shh5455 Mon, 05/07/2007 - 12:32
Thanks, but the Operational Status is still down. (Presumably because I have 802.11b/g disabled globally). Is there a way to override the global setting for individual APs?
ankbhasi Mon, 05/07/2007 - 22:59
  • Cisco Employee,
Hi Friend,
The only workaround is globally enable for all APs and manually admin down for respective APs for b/g radio. I agree its a tough job when you have 400 APs but if you can run some script it will be a matter of seconds.
And if you have WCS you can use AP template for that purpose which again will take less time than manual work.
Ankur
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
