davidwomer Fri, 05/11/2007 - 15:44
If you are trying to write Java code within your script its easy to use the expression editor.
For Example say you have an int value named myValue in your script
You can use the set from the script editor and within the expression editor write some code.
IE to set myValue to 50 * 10:
int multiple = 10;
int value = 50;
return multiple * value;
