"Sup720 Causes 6513 to Shut Down"
May 7th, 2007
We are trying to setup a 6513 with a Sup720. After 8 Minutes, the Chassis Shuts Down - The Red LED on both PSU indicating "Output Failure" lids up.
Chassis runs fine With Sup 2.
What could be the cause, How to Fix?
Thanx
avmabe Mon, 05/07/2007 - 13:16
  • Bronze, 100 points or more
Did you upgrade the Power and fan trays when you upgraded to a Sup720?
dgahm Mon, 05/07/2007 - 17:03
  • Blue, 1500 points or more
Willie,
The Sup 720 requires the high output fan tray. It will shutdown as you describe without it.
Please rate helpful posts.
Dave
keith.gardiner Mon, 05/07/2007 - 17:36
Look for messages dring the boot sequence relating to a the requirement for a high speed fan tray.
