Sup720 Causes 6513 to Shut Down
May 7th, 2007
We are trying to setup a 6513 with a Sup720. After 8 Minutes, the Chassis Shuts Down - The Red LED on both PSU indicating "Output Failure" lids up.
Chassis runs fine With Sup 2.
What could be the cause, How to Fix?
Thanx
dgahm Mon, 05/07/2007 - 17:02
  • Blue, 1500 points or more
The Sup 720 requires the high output fan tray. It will shutdown as you describe without it.
Please rate helpful posts.
Dave
Wilson Samuel Tue, 05/22/2007 - 10:27
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
Though its not generally talked about the PSU comes in various capacities and I believe that atleast 2500W PSUs are required for the Sup 720s.
Please check your present PSUs and determine if you require a PSU upgradation as mentioned by the other user,
HTH,
Kindly rate if it helps,
Kind Regards,
Wilson Samuel
