ip inspect problem
I have a problem with ip inspect on a C 827 router.
When i want make a connection to outbound it can not make a session with ip inspect firewall. When is use the command sh ip inspect session i don`t see details. If i disable access-list then everything works fine.
I hope sombody can help my.
This doesnt solve your problem, but I wanted to point it out.
Remove 'ip inspect dns-timeout 30' as this is synonymous with 'ip inspect name firewall udp' because when you inspect UDP, the UDP/53 falls into this category and the default UDP idle-timeout is 30 seconds.
Unless you increase/decrease the timeout value (in seconds) for 'dns-timeout,' you dont need the command.
