OSPF Design Help
May 7th, 2007
Can someone comment on the attached OSPF design plan. I have OSPF running at 4 locations.
Each locations have 2 WAN links from different ISP's on separate router.
Locations A, C & D should point to locaion B as the default gateway. Is this design correct?
Do I need to enable OSPF on the LAN segment of location A,B & C? Is it going to crete any routing loops?
Please keep fault tolerance and load sharing in mind.
Thank You
Overall Rating: 4 (2 ratings)
mohammedmahmoud Mon, 05/07/2007 - 21:57
  • Green, 3000 points or more
What is the WAN technology that you are using, if it is FR or leased lines, then your design is ok and there won't be routing loops or any kind of problems (in MPLS VPNs some problems might introduce due to the redistributions done on the provider side), but didn't you thought about having location B is area O and the other locations as separate Areas connected to Area 0 as a best OSPF practice.
HTH, please rate all helpful posts,
Mohammed Mahmoud.
avilt Mon, 05/07/2007 - 22:30
Its not MPLS, just metro WAN links. What's the need to run multilple OSPF areas?
mohammedmahmoud Mon, 05/07/2007 - 22:40
Using areas has many benefits, mainly boosting the convergence time and reducing the routing table size on all the routers, its not a must in your case as you don't have that amount of routers, but it is a best practice, you might think about it.
Mohammed Mahmoud.
waridtel.com Tue, 05/08/2007 - 03:07
I would also recommend to use different areas because it not helps in reducing routing table size (i.e. using less CPU Cycles) but also helps from troubleshooting point of view.
I would like to know the router hardware you are using for this design i.e. platform used for Location A, B, C etc.
HTH, please rate if it is helpful.
Rahim Amir Ali
sdoremus33 Tue, 05/08/2007 - 14:02
  • Bronze, 100 points or more
Depending on the size of your network 20+ you can have area 0 (Backbone, and depending on how far you want to summarize and clean up extra processing power, you have ABR (DG) @the core, and links to the areas (connected to area0 or via VL's). These areas can run NSSA pointing to the stub area area0, this also reduces database table size depending on the routers you will implement in this design
avilt Tue, 05/08/2007 - 18:05
Thank You for the valuable inputs.
I am using around 15 routers, Cisco 2600 and 1700 series. If I were to implement 2 areas, I will put all the routers under one ISP in area0 and others in area1. Do I need to configure ABR at 2 locations for backup? like one at locationD and another at locationB?
Thank You
sdoremus33 Thu, 05/10/2007 - 07:19
Depending on your situation you can either use a Single Border Router design or a Multiple Border Router design.
What you are talking about is the latter,which alieviates the single point of failure you eluded to,this allows BGP to add redundancy. Remember when designing make sure that the IBGP(Core) is running full mesh.
Also note that the enterprise should originate a default route for each border router which is injected into BGP to be redistributed throughout the network.
Not to sound like broken record but I like this design idea because it does give your organization redundancy.You simply troubleshoot your igp connection at each location(running OSPF).So the network receives prfix updates once recieved on the network.jRemember ibgp must run in a Full mesh remember:BGP avoide routing loops by blocking our of the interface it was learned on. Later Have agreat day
royalblues Thu, 05/10/2007 - 10:25
As suggested by Mohammed, it is best to run each location as a separate area especially when you have low end routers like the 1700 .
The ISP routers will be acting as the ASBR's and the 2 routers shown in each location will be ABR's as they will have one interface aligned to one area and the other to the backbone.
This will also provide redundancy
HTH, rate if it does
Narayan
