2811 w/CableDocsis and AP-AG card not recognized
May 7th, 2007
Just purchased a 2811 router with voice and wan cards. The voice cards pick up fine. For whatever reason, can't recognize the HWIC-Cable card and the HWIC-AP-AG card. with a show diag I get the following
WIC Slot 0:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
This happens for both cards but the voice cards come up fine. Have tried swapping the cards/slots around to no avail.
Currently running
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)
which I believe should support these HWIC cards. Anyone have any idea as to why I can't get either of these WAN cards to recognize in this 2811 ? Thanks.
Overall Rating: 3 (2 ratings)
Paolo Bevilacqua Sun, 05/13/2007 - 10:19
No, 12.4(3g) does not supports your cards.
The cable card is supported in 12.4((6)XE that should also support the AP card, introduced in 12.4(2)T.
Paolo Bevilacqua Sun, 05/13/2007 - 11:25
Hello found that also 12.4(11)T supports both cards an would be a betterchoice as it not life-limited train like XE.
