Road runner and 1760 router
May 7th, 2007
I would like to know if there is anyway to connect my 1760 router into my home connection. My ISP is roadrunner. I do not understand if you can have a router port obtain an Ip addres through DHCP. Any help would be apprecaited. Thanks
mohammedmahmoud Mon, 05/07/2007 - 21:40
Yes you can have your router interface obtaining its IP via DHCP using "ip address negotiated" command under this interface.
HTH, please do rate all helpful posts,
Mohammed Mahmoud.
