05-07-2007 09:09 PM - last edited on 03-25-2019 07:34 PM by ciscomoderator
Hi Guys,
We have an existing CME Setup which is configured and running, we would want to add another CME on the same network that caters to another department in the office, however we want the DNs on each other to be reacheable by dialing each others extension.
We are planning to configure H323 Gateway by matching the dial-peers on each end, I would like to know is there something like an Inter Cluster type of configuration that we do on the CCM that can be implmented on the CME.
Setup
VG1(Gi0/0)----Switch-----VG2(Gi0/0)
Sriharshaa Prabhakar
Solved! Go to Solution.
05-07-2007 09:24 PM
Regular voip dial-peers will work. You can setup something like this. Make sure the DNs dont overlap between the systems, otherwise you may have to use dial access codes like 8+<4digit number> of remote CME.
CME1
dial-peer voice 1 voip
incoming called-number 2...
dtmf-relay h245-alpha
codec g711ulaw
no vad
dial-peer voice 2 voip
destination-pattern 3...
codec g711ulaw
no vad
session target ipv4:
Mirror the config on the above dial-peers in the other CME router. With local DNs being 3XXX can dial-peer 2 with destination pattern 2...
If using CUE, remember to give hairpin commands such as
voice service voip
allow-connection h323 to h323
allow-connection h323 to sip
allow-connection sip to h323
Sankar
05-07-2007 09:24 PM
CME1
codec g711ulaw
no vad
codec g711ulaw
no vad
voice service voip
Sankar
