show crypto ipsec stats
May 7th, 2007
Can u help me out what this Decompressed bytes: 4933013 signifies in below command output.
if it signify compression ?? how to disable it
IPsec Global Statistics
Active tunnels: 2
Previous tunnels: 9
Inbound
Bytes: 4933013
Packets: 80348
Dropped packets: 0
Replay failures: 0
Authentications: 80348
Authentication failures: 0
Decryptions: 80348
Decryption failures: 0
Decapsulated fragments needing reassembly: 0
Outbound
Bytes: 4441740
Uncompressed bytes: 4441740
Packets: 74029
Dropped packets: 0
Authentications: 74029
Encryptions: 74029
Encryption failures: 0
Fragmentation successes: 3
Pre-fragmentation successes:2
Post-fragmentation successes: 1
Fragmentation failures: 2
Pre-fragmentation failures:1
Post-fragmentation failures: 1
Fragments created: 10
PMTUs sent: 1
PMTUs recvd: 2
Protocol failures: 0
Missing SA failures: 0
System capacity failures: 0
Vikas Saxena Sat, 05/12/2007 - 22:40
Is this for the VPN client or L2L?
What is your transform set?
Is this AES?
-Vikas
