VRID Peering.
May 7th, 2007
Hi i wan't to configure VRID Peering on the following configuration:
circuit VLAN89
ip address 195.177.246.120 255.255.255.128
ip virtual-router 101 priority 210
ip virtual-router 102 priority 210
ip virtual-router 103 priority 210
ip virtual-router 104 priority 210
ip virtual-router 105 priority 210
ip virtual-router 106 priority 210
ip virtual-router 107 priority 210
ip virtual-router 108 priority 210
ip virtual-router 109 priority 210
ip virtual-router 110 priority 210
ip virtual-router 111 priority 210
ip virtual-router 112 priority 210
ip virtual-router 113 priority 210
ip virtual-router 114 priority 210
ip redundant-vip 101 195.177.246.63
ip redundant-vip 102 195.177.246.51
ip redundant-vip 103 195.177.246.52
ip redundant-vip 104 195.177.246.50
ip redundant-vip 106 195.177.246.53
ip redundant-vip 107 195.177.246.54
ip redundant-vip 108 195.177.246.55
ip redundant-vip 109 195.177.246.56
ip redundant-vip 110 195.177.246.48
ip redundant-vip 111 195.177.246.57
ip redundant-vip 112 195.177.246.58
ip redundant-vip 113 195.177.246.59
ip redundant-vip 114 195.177.246.60
circuit VLAN46
ip address 10.2.46.248 255.255.255.0
ip virtual-router 100 priority 210
ip redundant-interface 100 10.2.46.254
I can only use a max of 8 vrid in a critical reporter and i have more then 8.
How do i do this?
I have the following for the VRID's.
reporter fateshare-rep
type vrid peering
vrid 195.177.246.120 101
vrid 195.177.246.120 102
vrid 195.177.246.120 103
vrid 195.177.246.120 104
vrid 195.177.246.120 105
vrid 195.177.246.120 106
vrid 195.177.246.120 107
vrid 195.177.246.120 108
vrid 195.177.246.120 109
vrid 195.177.246.120 110
vrid 195.177.246.120 111
vrid 195.177.246.120 112
vrid 195.177.246.120 113
vrid 195.177.246.120 114
vrid 10.2.46.248 100
active
exit
circuit VLAN89
ip add 195.177.246.120/25
ip critical-reporter 101 fateshare-rep
ip critical-reporter 102 fateshare-rep
ip critical-reporter 103 fateshare-rep
ip critical-reporter 104 fateshare-rep
ip critical-reporter 105 fateshare-rep
ip critical-reporter 106 fateshare-rep
ip critical-reporter 107 fateshare-rep
ip critical-reporter 108 fateshare-rep
ip critical-reporter 109 fateshare-rep
ip critical-reporter 110 fateshare-rep
ip critical-reporter 111 fateshare-rep
ip critical-reporter 112 fateshare-rep
ip critical-reporter 113 fateshare-rep
ip critical-reporter 114 fateshare-rep
exit
exit
circuit VLAN46
ip add 10.2.46.248/25
ip critical-reporter 100 fateshare-rep
exit
diro Tue, 05/08/2007 - 05:21
  • Bronze, 100 points or more
Frederik,
You should reduce the ammount of virtual-routers and assign multiple redundant vips to one virtual router. Normally when you have a setup with 2 boxes I advice 2 virtual routers. 1 Active on 1 box and 1 active on the other ....
Frederik1980 Tue, 05/08/2007 - 10:00
Hi Dimitri,
Thank you for the fast reply. As i understand correctly i can use one virtual router and assing X redundant vips. This will have no impact on my content rules?
Kind regards,
Frederik De Muyter.
diro Tue, 05/08/2007 - 22:40
normally not
Frederik1980 Wed, 05/09/2007 - 06:53
Hi Dimitri,
If i want to change my configuration i need to suspend all my content rules before changing to 1 virtual router.
Is there a command to suspend all content rules at ones?
