Trust Agent Deployment Package - strange problem
May 8th, 2007
with the standard Trust Agent, my NAC implementation works correct.
However, when I use the Deployment Package Tool, for example to change my authentication to "Use Single Sign-on ..." and I put the XML-files into the correct folder, after rebooting the modifications are adapted so it works correct, BUT every 4 minutes (or less), the client has to re-authenticate. If I remove the XML-files and reboot so the Trust Agent works in standard mode again ,then the re-authentication problem disappears ... I've already tried to raise the re-authenticate timeout level in the Catalyst Switch but that doesn't help. Also, I cannot find anything of it on the internet. Anyone who knows what the problem might be?
Thank you
chenyokechuan Sun, 05/20/2007 - 07:27
Do you check ACS configuration? Maybe is not switch re-authentication problem.
