We have recently set up a 6509, experiencing errors on both of the
WS-X6748-GE-TX modules. Its on the trunk interfaces to 2 cisco WS-C3550-24.
When we moved the trunk to the sup port
we got no errors.
We are planning to connect a pc to the ports to see if the problem persist.
Any ideas ?
#sh int GigabitEthernet1/3
GigabitEthernet1/3 is down, line protocol is down (notconnect)
Hardware is C6k 1000Mb 802.3, address is 001a.a249.8aaa (bia 001a.a249.8aaa)
MTU 1546 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 0/255, rxload 0/255
Auto-duplex, Auto-speed
input flow-control is off, output flow-control is desired
Clock mode is auto
Last input 1d03h, output 1d03h, output hang never
Input queue: 0/2000/100455/0 (size/max/drops/flushes); Total output drops: 1
Queueing strategy: fifo
Output queue: 0/40 (size/max)
43209443 packets input, 51556057716 bytes, 0 no buffer
Received 9745 broadcasts (9148 multicast)
100455 input errors, 0 CRC, 0 frame, 64 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
43208415 packets output, 51699821574 bytes, 0 underruns
1 output errors, 0 collisions, 2 interface resets
Bjornarsb
