XOT session
Answered Question
May 8th, 2007
Dear all,
If an X25 route is configured on a router with an xot-source using an interface that has no IP address assigned, will the router by default use the wan interface? This is what is happening on routers running 12.0(11)ip plus.
Correct Answer by paolo bevilacqua about 10 years 1 month ago
with XOT, as like with other things, in lack of a source specified, router should use the interface used for outgoing to destination. Even if unnumbered, it should have an address.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Tue, 05/08/2007 - 05:10
  • Hall of Fame,
    Founding Member
paolo bevilacqua Tue, 05/08/2007 - 05:25
  • Hall of Fame,
    Founding Member
Thank you for the nice rating and good luck with your project!
