T.37 On-ramp Faxing details
I have used the T.37 on-ramp faxing before for clients, but never used the wildcards to make it easier on myself (or I thought). Has anyone implemented this using the '$d$' wildcard to send fax-emails to the server?
http://www.cisco.com/en/US/partner/tech/tk652/tk777/technologies_tech_note09186a00801fe5d9.shtml#optional_config
According to this and the traces that I have seen you have to create email accounts with 'FAX=xxxxxxxxxx' where the x's notate your incoming dialed number (could be 10 or less digits). But the point is that my client says that he cannot use the '=' character in an email alias. Has anyone found a way around this?
thanks
paolo bevilacqua Tue, 05/08/2007 - 17:27
  • Hall of Fame,
    Founding Member
I cannot really help with your question (apparently "=" is allowed per rfc in the local part of email), but since I was researching the subject, wanted to ask you, which platform / IOS are you using?
All the documentation references a builtin fax_on_vfc_onramp_app that is not present the the latest images for 2800 ISR.
Thanks!
paolo bevilacqua Tue, 05/08/2007 - 17:59
  • Hall of Fame,
    Founding Member
Hi and thanks.
I've downloaded app-faxmail-onramp.2.0.1.3.zip but it does not define the fax_on_vfc_onramp_app service. I can configure that under a mmoip DP, but I think it will not work ? I do not see any other relevant file in the TCLware page.
What do you see doing
sh call application voice summary
on your 2811 ?
It does take a reboot before the service is available, I assume you have done this.
router#sho call application voice summary
SERVICES (standalone applications):
name type description
ipsla-responder Tcl Script builtin:app_test_rcvr_script.tcl
clid_authen Tcl Script builtin:app_clid_authen_script.tcl
clid_col_npw_npw Tcl Script builtin:app_clid_col_npw_npw_script.tcl
Default C Script builtin:Session_Service.C
CTAPP C Script builtin:CallTreatment_Service.C
clid_authen_col_npw Tcl Script builtin:app_clid_authen_col_npw_script.tcl
fax_hop_on Tcl Script builtin:app_fax_hop_on_script.tcl
ipsla-testcall Tcl Script builtin:app_test_place_script.tcl
fax_onramp Tcl Script flash:app_faxmail_onramp.2.0.1.3.tcl
clid_authen_npw Tcl Script builtin:app_clid_authen_npw_script.tcl
session Tcl Script builtin:app_session_script.tcl
clid_authen_collect Tcl Script builtin:app_clid_authen_collect_script.tcl
clid_col_npw_3 Tcl Script builtin:app_clid_col_npw_3_script.tcl
lib_off_app CCAPI Libretto Offramp
DEFAULT.C.OLD CCAPI Obsolete system session application
fax_on_vfc_onramp_app CCAPI Fax onramp for VFC
PACKAGES:
tcl20base C Script builtin:tcl20base_package.C
cantonese C Script builtin:package_cantonese.C
media C Script builtin:package_media.C
vxmlbase C Script builtin:vxmlbase_package.C
destination C Script builtin:Destination.C
english C Script builtin:package_english.C
appcommon C Script builtin:AppCommon.C
httpios C Script builtin:package_httpios.C
indian C Script builtin:package_indian.C
callsetup C Script builtin:CallSetup.C
session_xwork C Script builtin:Session_XWork.C
french C Script builtin:package_french.C
greek C Script builtin:package_greek.C
chinese C Script builtin:package_chinese.C
consult C Script builtin:Consult.C
vietnamese C Script builtin:package_vietnamese.C
tclmodule C Script builtin:TclModule.C
consultresp C Script builtin:ConsultResp.C
german C Script builtin:package_german.C
tclcore C Script builtin:tclcore_package.C
vxmlmodule C Script builtin:VxmlModule.C
russian C Script builtin:package_russian.C
spanish C Script builtin:package_spanish.C
thai C Script builtin:package_thai.C
japanese C Script builtin:package_japanese.C
digitcollect C Script builtin:DigitCollect.C
router#sho ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 06-Nov-06 02:36 by alnguyen
thisisshanky Tue, 05/08/2007 - 18:45
  • Purple, 4500 points or more
Just as a side note:
Cisco recommends that you dedicate a router for offramp/onramp faxing, as the rendering of the fax into tiff format and back can consume a lot of memory and CPU. Same with Unity server. If you have lot of users using this feature with Unity, you may as well buy a third party fax server like Rightfax or Cisco fax server (Captaris).
