DHCP Snooping binding Database empty
May 8th, 2007
we're experiencing a problem which happen randomly with Cat3750...
The CPU usage increase over 60% for a period of time and we've not yet defined the exact cause...after that the DHCP Snooping Database on the switch start to release the IP Address..after some hours the Database is empty ad we should reload the switch...
The switches are configured for DHCP Snooping with Port-Security for MAC Address, IP Source Guard and DAI...with Proxy-ARP active
Anyone has already experienced something similar???
I've seen a docs about Cat3750
"Catalyst 3750 Series Switches High CPU Utilization Troubleshooting" and one chapter states ==>>> High CPU Due to Excessive ARP Request ...
Overall Rating: 1 (2 ratings)
oguarisco Mon, 05/14/2007 - 06:03
I Know thanks my question was if someone has already experienced that the DHCP Snooping binding table is become empty and the CPU on the switch is increasing during the entry are timing out...
Luckily I've discovered that was a problem on the DHCP Server...BIG problem since it didn't renew the IP Addresses and the lease were aging out on both the servers and the switches
