Callmanager 5.0(3) upgrade to 5.1(1)
May 8th, 2007
I have a customer that was a CM 5.0(3) installed and want to upgrade to CM 5.1(1), he was buy the upgrade, where do i download the new software?
Thanks in advance
mchandak Tue, 05/08/2007 - 06:26
You can download the upgrade file for 5.1.1b from http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-51
The files are:
1. ciscocm-5-1-1b-ReadMe.pdf
Readme for Cisco Unified Communications Manager 5.1(1b)
2. cisco-ipt-k9-patch5.1.1.3000-5.tar.gz.sgn
I'd recommend installing the latest DevPack as well. You can get it from the same link
