A problem with MWI Light that does not flash when message is waiting
g.lacoursiere
WMI, is not an easy thing to understand and to configure. I have just solved the problem for receiving messages, and now the WMI does lignt on when there is a message for a user. So it must be some glich, because I think that I put everything correctly for WMI.
I attach my config files so someone can help me find my problem.
Thank you.
5 Replies 5
thisisshanky
Level 11
Level 11
Are the phones running SIP or skinny ?
If your extensions are 2 digits, your MWI on number should be 57.. and MWI off number should be 87..
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Hi, I am not completely certain that my phones uses SCCP. Thoug in all the config I have made, I work thinking that they where SCCP. How can I make shure ?
Also, I have tried what you said addng the following commands.
"no ephone-dn 19 dual-line
ephone-dn 19
no call-forward busy 99
no call-forward noan 99 timeout 18
number 57
mwi on
no ephone-dn 20 dual-line
ephone-dn 20
number 87
mwi off
But there is still no blinking red light on the phone that I leave a message on (ie 57).
So there is probably a miss configuration between sip and SCCP ? Or I dont' know what exacly.
Thank you for for your continuing help
As Sankar said make sure you include the ".." such as number 57.. if your extensions are 2 digit long.
Take a look at this doc (page 14)
http://www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/cmeinter/cue_cme1.pdf
HTH,
Chris
Thank you very much.
The lights are on,
but your not home,
your mind
is not your own.....
Oups, got a little excited....!!
neesharm
